- Oct 18, 2016
- 2,872
Great. Let us know how that works.
I have both Aloris and chicom holders, the Aloris is worth the extra cost. Also, some of the cutoff blade holders have centering grooves that hold the blade without tilting. My Phase II holder doesn't.
Couldn't you just machine a small slot along the top of the cutoff blade holding surface on the tool holder (that way you would not have to use a shim to keep the "T" type blade flat)?
The real issue, at least on my Phase II BXA holder, seems to be that the bottom of the blade is unsupported on both sides and moves, leaving the blade not vertical. A shallow slot at the bottom of the blade recess might be better, and shimming the bottom on the inside might help best without modifying the holder. There is not enough room to mill a slot at the top clamp, my T shaped blade fills the available width.Couldn't you just machine a small slot along the top of the cutoff blade holding surface on the tool holder (that way you would not have to use a shim to keep the "T" type blade flat)?
