Hi -- I'm slowly getting up to speed with my new PM 1030 lathe, having spent quite a bit of time leveling, aligning, etc. and making a couple projects.
Of the things I've done on the lathe, parting off is the one thing I've definitely not mastered -- I get shallow conical surfaces on the two sides of the part.
My set-up and things I've done:
Practicing by cutting off the end of a 1" 6061 bar.
1/16 x1/2" cutoff blade in a cut-off blade AXA holder.
Just enough stick-out to reach the center of the work.
Blade tip precisely centered (triple-checked).
Blade tip ground perfectly square.
Blade adjusted to be perfectly square to the previously-faced end of the work.
Plenty of cutting oil (drenched).
Rpm ~600.
Slow advance of the blade into the cut, with frequent oil application.
Bar is sticking out of the 3-jaw ~1".
So, what am I missing? Is the 1/16" blade too thin for this task?
Thanks for any suggestions!
Mark
Rpm ~600.
Mark
