T15 is also HSS. There are two basic types of HSS, one based on Molybdenum (for instance M2, M42, etc.) and the other based on Tungsten (T1, T-15, etc.) (Also a third based on Cobalt, Stellite.) Tungsten HSS has often been superseded by Moly HSS in more modern times for cost reasons in a changing metals market. Simply stated, Molybdenum is cheaper than Tungsten today. There are also some other subtle reasons why one type might be picked over the other for certain tasks, they are not identical in their properties. I have a pretty good selection of different HSS tool bits of different alloys from different manufacturers, and it is interesting to see the differences in how they act in the cut under different conditions.
https:n//www.asminternational.org/documents/10192/22533690/06022G_Sample_BuyNow.pdf/b8f2e317-5089-44bc-a14d-af31f80e33a5
http://www.crucibleservice.com/eselector/prodbyapp/highspeed/highspeedapptitle.html
Hi Everyone, I have what Im sure is an easy question for most of you. I installed a quicj change tool post on my G0752 lathe. With it came a cut off blade holder. It says I need to use a blade that is Parrellel top and bottom. Does that mean I can not use a T shaped blade in it or is that ok? Thanks for your time on this.
I guess you have the wedge type parting blade holder. The one I use is called a SHARS P3N "P" Type 3/32, make sure to get the right size. My BXA holder takes 11/16 blades you may need the 1/2" blades at 1/8"? I buy blades one at a time, so the "Discount Tool eBay Store" is my go to place for small purchases. Shars blades have been fine so far. The 3/32" blades hold up better for me on my 12x36.
I ended up switching mainly to carbide insert tooling a couple years ago, I use the MGM-200 size grooving tools with decent quality inserts for the application. I've been using the Korean Korloy 3030 MGM-200 for my steel parting operations and I have a couple other no-name Asian brands that I like too. I do a lot of grooving and I just part with the same tool. Easier that way. So far the Asian tooling has been cost effective with decent durability. I get far more parting operations from an insert tool before I need to sharpen a cut off blade. Its a time saver for me. The MGM-200 size works well enough I haven't tried other carbide sizes. The ones I use are cheap, about $9 to $14 for ten of them. I only have a slow 12x36 lathe, but I find carbide works fine for some things. Its very convenient.
The best thing I ever did to help with the parting cuts was adding a cool mist system, it beats oil and flood coolant hands down. I haven't used flood coolant in a long time. I run a cheap mister from bangood.com with Kool Mist 77, makes things much more pleasant and parts come off just warm to the touch. The air pressuer blows out the chips and the coolant lubricates and cools. I run 6 oz to a gallon. I put these on my Lathe and on the bench mill, they work great IMO for $14: https://www.banggood.com/Mist-Coola...e-Cooling-Sprayer-p-987371.html?rmmds=myorder
I hate to jack the OP thread but what else do you need to go with the coolmist from banggood ? Does this help directly up to the air compressor and no fluid pump is needed ? I don’t really know much about any coolant system other than dipping the brush in oil, lol
8 mm (.315") is equivalent to 5/16" (.3125"). That is the correct size for the vinyl tubing needed for the air connection. The connections are quick, foolproof, and easy to install and remove.The mister uses an 8 mm air line, thats 3/16" I.D. vinyl line I think.
