I have done some powder coating in the past using both the Eastwood Hotcoat system and the HF system. They both work fine. Biggest problem is handling the un-cured powder coated parts. Small parts I did in an old electric kitchen oven (don't try a gas one and don't use the one in your kitchen!) and make sure it isn't a convection type - the air in the oven needs to be still to keep from disturbing the powder. The type of powder determines a lot of things - curing time, curing temp, UV resistance, chemical resistance, etc. Film thickness can be controlled just like painting - put on just enough and not too much (yep - it'll take a practice run or two - just like painting) Need a still place to coat close to the heat source and small parts are pretty easy. Larger parts can be done using in IR heater (no fans!) It is messy - the powder is very fine and respirator should be worn whenever handling it, let alone when spraying it. Water must be kept out of the system. Check out the Hotcoat site for all the details. Powders can be purchased off ebay as well as from HF and Eastwood. Pay attention to the powder type and make sure you use the one you need to get the type of end result you want - Most epoxy chalks really bad in UV for example. Polyester is pretty good in UV, but softer that epoxy, and a little less chemical resistant. Also, most powders must go over bare metal or special powder type undercoats - no filler under the powder coat. It's been a few years, so I'm sure some things have changed since I last played with it.
