- Jun 20, 2024
- 21
I have a new-to-me Emco Compact 8 that I'm trying to get set up for little projects. I ordered an OXA QCTP from LittleMachineShop so I could swap tools easily. I've never run a lathe before, but managed to make a new stud to mount the tool post that worked great with a little time and patience (though it wouldn't win any awards from a real machinist, I'm sure). All of the tools I ordered fit great and can be centered up perfectly using the adjustments on the tool holders. The exception is the cutoff bar. It was above center by 50-75 thou. My great idea was to carefully hone the cutoff bar down so that I'd have a little adjustment room, so I took 100 thou off of it....and now it's too short for the clamp to secure it in the holder. The only solution I can think of to that is to add a shim at the top. Is that safe? The shim I have in there is not what I'd use - just what I had laying around. If it's a safe way to clamp it in there, I'll order some proper shim stock and cut it to size. Any other ideas? Thanks in advance for your help!
Wes
Wes
