- Apr 29, 2019
- 2,211
I was reading with great interest the thread https://www.hobby-machinist.com/threads/adhesive-for-veneer.113979/
It has inspired me to look further into fixing the front door on my house.
On the current door the original factory applied veneer is peeling and needs to be replaced. My application is a bit different than the other thread but there has been good info on what might work for me on this application that is outdoors.
It will see temps from -30°F to +110°F, and get rained and snowed on, at least it is on the north side of the house so it will only get early morning and late afternoon direct sunlight during the summer.
The plan is to take the door off the hinges and remove all of the original veneer and as much of the old glue as possible. Probably by first scraping to get the big loose parts off and then sanding using a DA and/or belt sander starting with 80 grit and working my up until it is a smooth solid surface.
Currently the outside of the door is painted with an outdoor paint and the inside is clear varnish. The edges are also painted the same as the exterior. I would like to sand the edges down to bare wood and have a clear finish on both inside and outside of the door. If I go clear finish then I can use a nice looking veneer like maybe Birds Eye Maple The inside looks great and I do not plan on refinishing it at all.
From what I have been reading, there is no clear exterior finish will hold up long term other than paint. If I go paint again then I can use some cheap veneer shut to get back to a smooth surface for the paint.
So the questions are.....
1. Best adhesive for this outdoor application?
2. Is there a cheap dirty way of making a vacuum bag around this door?
3. best finish system will hold up the longest outdoors and be reasonably easy to refinish down the road as required?
