- May 23, 2015
- 66
I've ordered a couple new blades from BandsawBlades Direct. I was also talking to a gentleman in a local shop that has two older Ellis saws. He also brought up the suggestion to check the downward pressure. I have checked it several times over the last year but decided to give it a check again. I checked the weight, and it showed about 8 pounds. However I borrowed a much better and more accurate scale. Mine is a pretty good fishing scale that I rigged up from a step ladder so that I could hang it in direct line with the saw head. Just out of curiosity, I tied the two scales together on the workbench so that they would pull against one another. I put a pulley over the end of the bench and hung a 10 pound weight on it. The other end was anchored to my bench vise so it was rock solid. The borrowed scale showed exactly 10 pounds. The fishing scale showed 7 pounds. Then I used a ratchet strap to pull the tension on the good scale to 8 pounds and my old fishing scale was only reading about 4.5 pounds. Sooooooooo, it appears that I have been running the 1600 far too light. I have adjusted it to just a hair over 8 pounds now so we will see how the new blades work out. They should be here today. Thanks for the help. Another reminder that quality tools do make a difference.
