- Sep 14, 2014
- 710
I want to state up front I don't know squat, and absolutely do not want to start an opinion war. This a serious question. If I could have found an answer on the two forums I searched I wouldn't ask. Also I'm post surgery single handed on a tablet so please excuse typos I don't catch.
When watching Quinn (Blonde Hacks of whome I am a minimum level Patron) machine a raw casting for a packing, she said right up front she was eye balling the setup and from my own error prone experience wasn't surprised when attaching the part it would only go on one way because the three holes didn't share a center line (hope that's close to the correct term). Learned several days later there had been some blow up over this and the same issue with Joe Pie's work. Honestly I don't care. I do want to learn how others might approach the set up so all three holes are centered. My thoughts follow, please shoot it full of holes as necessary and give your thoughts.
- Flatten the flange base using a vice
- flatten the top of the flange center.
- Get the average the width of the two flanges
- drill a small hole in the flange center
- use a screw to clamp down the flange using the small hole to a sacrificial plate and a couple of clamps to prevent spinning.
- Establish the center line, flatten and drill the screw bosses
- use the screw bosses to clamp down the flange
- remove the center screw and drill/ream to size.
