I have the Dewalt 611 trim router and think it is grand! I also have the same air powered pencil spindle noted above as Jim and the guys here helped me get my high speed engraving spindle basics nailed down. The only item I have a comment on is related to Carbide small end mills on high speeds. I tried that. Broke most everyone of them (with CNC being used for engraving). So brittle and delicate. Of course, I am also very new and learning but did fare much better with HSS in those really small sizes. I now also love Cobalt. I'm just curious what type of material you would use these Carbides and higher speeds upon? When I used my setup for engraving on Brass- the carbide would just not last long when cnc driven. I also ran them on Steel and Stainless. In the end I needed a mount w/ a spring spindle and HSS. Thought I would toss in my newb feedback on really really small carbide EMs
My choice of materials is aluminum and mild steel. I'm considering carbide because the high speed spindles and router motors I've looked at are rated 10,000 RPM on the low end. 10,000 RPM is too fast for a 1/8" HSS end mill in mild steel. My mill's top speed is 1,970 so I have a gap to fill between 2,000 and 10,000 RPM.
I've been in the machining industry my entire career (45+ years) so I understand feeds, speeds, chip load, chip evacuation, etc. but I don't have any experience running end mills smaller that 1/8" so I appreciate your feedback on using small diameter carbide end mills. Always something new to learn.
Tom S
