Optical Centering Microscope
Wow....just wow!
-brino
Thanks guys!
To calibrate the centering I used the lathe because I know it does not have a headstock angle error. I put a spot drill in the lathe chuck and drilled a tiny hole in a piece of material mounted in the tool holder. Then I swapped out for the microscope. The drill hole was slightly off center. I used the 4 screws like a 4 jaw chuck to line up the drill hole. Bam! I had a little motion when I tightened down the 3 holding bolts so I had to repeat a few times to nail it. Not too hard.
The depth of focus of this system is very narrow so you are always at a fixed distance to the target. I should be able to calibrate the scale in terms of inches and mm also.
If you have a tramming error the center will appear to move off center as you rotate the spindle.
I think this will be very useful and same tons of time. I'm tired of screwing around with cigarette paper! Also centering for drilling on punch marks will be a snap.
R
I should note some details. The mirror is a first surface mirror. $8 for 2 on ebay. The eyepiece is 10 x and the objective is 4 x so about a 40 x magnification. You could buy an old microscope on ebay for less than I paid for the eyepiece new. My mirror box is not perfect. I should have started with 2 x 2" stock so I had square parallel sides to start with. Then turn between centers to create the bosses at the top and bottom. Then cut out the pocket. Then bore the hole for the tube and thread it 36 TPI. . Then turn all the sides on the lathe to make it pretty. I will eventually do that. Also, you should note that microscopes use a 36 TPI thread. Interesting because the objective lenses are threaded 20.1mm x 36 TPI (yes metric and imperial) They are Whitworth but I used a standard 60 deg thread and it works fine.
Robert
Did you notice how I snuck the articulated arm holder in there...
R
I was playing with this to see how accurate it really is.
I drilled a tiny hole in aluminum with the tip of a 1mm drill with a sharp chisel point. I then put the optical center in a collet to see how well the mill spindle lined up with the reticle.
It was a little hard to photograph but...
I would estimate the OD of the hole to be no greater than 20 thou. so I am probably within 1-2 thou of center? I could adjust this closer but this works for me. It is similarly centered when I rotate the spindle 90 deg each way. Is there another test I could consider?
It's been a while since I've played with my Skoal, But I've added trying to get a similar photo to my "After Shoulder" list:
My iphone has 3 lenses so it would not work. I had to go back to my old Pixel!
