Early fifties as near as I can tell. The Smith welding equipment company in Minnesota made gas welding equipment, acetylene generator units, and arc welders. Also had a talent for art deco design apparently.
Mark S.
The MK2 isn't so bad really but I don't like how they did the sliding coupler. The one little woodruff key has to carry all the force from the pulley to the spindle- they should have used 2x 180 degree keys or a spline design. There's also noticeable deflection with heavy cuts especially with the ball bearing version.
Mark S.
Just because the major diameter [of the 618 spindle nose threads mentioned in an earlier post] has a taper, does not mean the pitch diameter is tapered. Check it with thread wires or a pitch micrometer.
