maybe 3/8 would fit.
i was / still might mount it on my "Oliver of Adrian" ace grinder and attempt to use it for a make shift but very accurate surface grinder. the arbor on the machine is quite short, im going to look closer at making a bushing.
first job to grind / flatten my magnetic chuck, then a couple of compressor valve cases. id need to stand with a squirt bottle of coolant im sure.
