Old Lathe Threading Woes........what I Learned
I also have a South Bend heavy 10L (my first lathe), but still struggle to make proper threads. I'm pretty certain it's me and not the lathe... The difficulty I have is making sense of depth of cut. At an angle, the cutter isn't cutting as deep as the dial says and I understand this (it's at an angle after all...). Is there a quick rule of thumb for gauging depth of cut by the compound dial, or should one simply cut, measure, cut, repeat...?
I use a dial indicator.
.866 of the dimension moved with the compound at 30 Deg.
