- Jan 25, 2015
- 60
I had a Grizzley 12" modern lathe for a decade and could cut the most beautiful threads. I would really whirl the machine when I was cutting the threads, like 400+ RPM and I could do it all day long.
Well after a life event where I had to replace my entire shop and all my equipment I ended up with a 1944 Southbend 16" lathe. The lathe is in wonderful condition and I restored anything that was needed right up front.
This lathe does not have a thread dial and you cannot add one due to the lead screw having a groove all the way down it length. Trust me I tried, but it gets out of sync when it rotates over the groove. This however is not a big deal I can cut threads without a thread dial.
So I started cutting threads and they were horrible. The machine would make 5 perfect passes and then it would split the thread in the middle. I know all the fundamentals of threading, alignment and height so this wasn't the issue.
I just happened to find an old book called "How to run a Lathe" by Southbend. It recommended running the lathe in the slowest back gear for threading. So I gave it a shot, hell I had never even had a back gear on my other lathes. Man it turned SLOW but cut (formed) the prettiest thread I have ever seen.
The moral of the story is these old machines CANNOT cut threads at high speeds like modern lathes. Also a good sulfur based cutting flood is essential when cutting threads on these old lathes at slow speeds. The results however are worth the effort, finely formed threads with smooth shiny contours. No shearing, tearing or ragged cuts.
I am glad I figured this out, I was about to go out and buy another Chinese modern lathe, honestly though I prefer the nostalgia of using a 75 year old lathe. There is just something abut working on it knowing many men have used it over the years, it has a story of it's own (Sorta like my Ex-Wife).
