Old Craftsman Stuff
Paul,
His problem isn't just the spring. He is missing the entire quill return unit.
Paul,
I didn't craft my reply too well. I suppose I should have said "If you find or make the other parts, here are places you may be able to get a custom or similar spring..."
Sometimes the other parts are 'makeable' but creating springs, especially if it is a flat coil spring, can be a challenge.
Got spring assembly from ebay , it won't work it is a coil spring with a fork coming out of knob. There is the rite one on eBay but the cap/knob is broken it dose have the strap spring tho $10.+10 shipping I wrote seller note .
Joe at plaza dose not have one, the 150 assembly may be able to be modified , Ben to busy to check rite now. But it's on the list.
Thanks
Ok I got the rite quill return assembly from eBay , the cap is damaged but still works the strap spring is good and it came with the gear shaft that I don't need . The quill return now works !. I have a 150 quill return assembly that I won't need
Thanks all
Derrick
