- Aug 3, 2017
- 2,419
Well, the big part about lapping is that the compound 'wears out' really quickly. You end up having to replace it pretty often (so more than every 20 minutes or so, particularly at RPM). But this is probably at least a long day's project. I know the handful of times I've done lapping (even with some pretty harsh valve compound), any amount of visible surface deformation took a LONG time.Yep. Got that covered. This is just kind of a curiosity. Something to try. Maybe an alternative for the TP grinderless. I've never done any machine lapping. It seemed like a kind of effortless idea. Just turn it on and let it run, check on it every twenty minutes or so...But if we're talking days, maybe not so great.
One thing you might think about... I wonder if you could get a diamond coated 'burr' of a large enough size, and use that? It should accomplish the same thing as a tool post grinder, without having to use a motor (since it should 'wear out' more slowly).
You MIGHT have a hard time finding something like this though, my first quick googling just resulted in dremel tooling.
