Old Brown & Sharpe 10" dividing head
Ken,
I knew it was old because of the off center index handle and it doesn't have rollor bearings for the spindle. I have a PDF copy of the B&S 1913 catalog that shows dividing heads with the offset handle. I also have a pdf of a old copy of the B&S #2 mill manual that show the dividing head as having bearings.
I finished the pop up oilers today.
Next on the list is a thread gauge for the spindle so I can make a face plate, chuck adapter and spindle thread protector cap.
Too bad I didn't see that center last week when it didn't sell for $25. Somebody wanted worst than me and paid $45 plus shipping this week.:nuts:
I'll just set up the taper attachment on my lathe then turn and grind one from some prehardened 4142 I have. I have a #10 B&S reamer that I cleaned the spindle bore up with that I'll use to set the taper attachment.
I've just acquired a very similar 10" B&S dividing head. I've started to take it apart today. The one thing that seems frozen is the knurled knob on the "non crank" side. It seems to connect to a small gear that runs through to the crank side. I noticed that in the first pictures of this thread that your machine has the same thing. For the life of me I can't figure out what this is for!! (And I'm not looking forward to fabricating a chuck backplate with their goofy 2-1/4 x 4-1/2" thread)
That knob turns a gear inside to rotate the worm in and out of engagement. The unknurled part is a lock nut. Loosen it first and then you can rotate the knurled knob to dis-engage the worm so you can turn the spindle by hand.
I never did find a complete dead center for the dividing head but I did find a #10 B&S center with the straight diameter for the bar to drive a lathe dog. I made the bar based on the picture of the one that sold on Ebay for $45.
Don I've been looking for that manual but I guess I've lost it or put it away where it would be safe.
I had up loaded it to the old site but it never made it here. I guess it went to the same place as mine.
The bar looks good but mine doesn't have the locking bolts on it.
Paul
