Cleaning up the wheel dresser so I can start using it. Took it apart and noticed this...
The bottom shaft is from the dresser, the other part at an angle is just a piece of stock I had that fit.
The bore that the stock is in is where the diamond dresser goes... look at the angle, is that normal. It looks like it was meant to be that way.
Does anyone have experience with this brand of grinder? I have messed around with it to make it run back and forth in X and index in Y but I would like to use the dresser, it would be cool if it compensated for the dressing cycle for the depth of cut.
