- Feb 8, 2014
- 11,176
Your calculated spindle speed and formula are correct. BUT, those numbers are for a new, sharp end mill, cutting under optimal conditions in a production environment for maximum metal removal rate. The home shop rarely has optimal conditions, so we make allowances.
Normally half of those speeds is a good starting point. The worst enemy of an end mill is heat. Slower speeds = less heat.
A air nozzle or a mist coolant system would be very helpful. I use one or the other depending on what I am doing.
