Offset boring through rectangular blank
Hmmm, really wanted to buy a toolpost next.... :frown:
I may try your suggestion, Savarin but I dont think I'll stand in line with the cutter this time when I do.
It would be nice to have this part done.
Yeah , really . That thing sounds dangerous ! Out of balance and loose jaws can spell disaster especially at high rpm . Imagine cutting the OD with an interrupted cut ! :cautious: But yes , savarin summed it up above .
Put your dimensions on here . I most likely have the aluminum and the time . If I do it , shipping cost would do . I would rather not hear about someone being injured on the site . :cool:
I spend nearly an entire 40 hour week every 2 months or so turning square and rectangular parts in a lathe using a 4-jaw chuck, my employer holds all of this work so that it is done at one time after the chuck change which takes some time.
I fail to see your problem.
Chuck it, indicate the location and have at it, I often use different jaws for this work depending on the part shape and size.
Glad you got this sorted but let me be especially ignorant here. Your chuck has screws that lock down the jaw adjuster bolts once the part is secured? I've not seen a chuck like that before - learn something every day!
Aww, thanks mmcmdl. That is very kind of you.
It will be an interrupted cut almost the whole rest of the cut too.
Perhaps if I bump up the dc conversion before this, I can slow it down to a not so fatal speed.
I may feel confident enough to try it then.
LOL! Yes it is a weird chuck!
I think its meant as a wood chuck, mine broke and the replacement they sent also went westward soon after but it did give me another face plate..
In my humble opinion the list of jobs to do on the 9x20 in what I think is a good order is...
1, Make a solid plinth to replace the compound, you can thread at 90' so you really only need the compound for short tapers, This mod alone boosts rigidity by a huge percentage and makes parting off a breeze.
https://www.hobby-machinist.com/threads/plinth-for-qctp-on-9-x-20-lathe.45628/
2, Get the QCTP and extra holders of choice, AXA works well with these lathes, I like the wedge type but there does not seem to be much difference in rigidity overall. Make sure the centre post is the correct size for your tool post holder. The one that comes with the lathe is a bit flimsy.
I bored out the original 4 way tool post so it would fit the 14mm shaft required for the QCTP and could be used until you get the qctp
3, A real 4 jaw chuck, dont forget a back plate unless you want to make your own.
You can set the block up in the three jaw by using the three jaws to the side, ie, two jaws on one side and one jaw on the other side and squeezing the block between them, if you lucky the hole will be where it can be bored. (its worth a look to see if it will line up)
The first couple of shots show what I mean by gripping at the sides of the jaws and how the centre would be off set if using the three jaw, you can also off set the same way with the 4 jaw.
https://www.hobby-machinist.com/threads/a-vertical-slide-for-a-9x20-lathe.49724/
also how much stickout can be accomplished with care and fine cuts.
https://www.hobby-machinist.com/threads/the-9x20-mods-thread.30050/
post 12 to see offset boring the compound slide to fit the 14mm post.
Hope this helps.
Huh, I'll take a look at the 3 jaw.
I have been fooling with this 4 jaw this evening.
This thing is a nightmare.
Seems like its impossible to tighten the stock and have it be square to the jaws. Stuff shifts as it draws up tight. I think you're right about it being wood chuck.
It just might work in the 3 jaw too!
Thanks for that tip!
Savarin, I also like your qctp mod too. I've been looking at axa tps. Seems like they do need to be raised a bit. I also like the 4 bolt design on yours too!
