...or ask here.
You will get such varied opinions and methods that'll you'll have to read the thread several times to get all the nuiances, and then you can design a custom process using the best parts of every other method.
-brino
Yep did that the other day. Made two brackets for my new ute tray. One I measured worked perfectly, but the second one did not allow for the fact that the tray builder did not put the under tray gussets in exactly the same spot. Bugger - so now I have to make a second bracket that is slightly modified. Did I learn a lesson, well maybe not, I am sure I will many more such unnecessary mistakes in the future. Attached is a photo of the bracket that fitted correctly. That is our slide on camper which sits on the tray of the vehicle. Cheers Mal
