- Dec 18, 2019
- 7,495
I have to install some NBR90 1.5 x 4mm ID o-rings onto a 6.95mm OD high pressure air probe. I did one NBR70 for a bumper and managed to get it over three grooves, but it wasn't easy at all. The second o-ring, an NBR90, I could barely get it into the first groove, which as a mere 2mm from the end of the probe. I'm having zero luck with the last o-ring, another NBR90. It split on me, when I attempted to stretch it. Is there some sort of trick to install these little stiff o-rings? Help me achieve enlightenment. At the moment I feel like I'm wrestling a greased pig. I need about 6 hands and have 2. The o-ring on the right is NBR70, the other two are supposed to be NBR90. Appreciate any tips. Part is 38mm long, narrow end is 6.95mm, wide end on the right is 7.86mm OD. Right side o-ring is only a bumper, it doesn't seal.
