Norton 5SG Vitrified Toolroom 7" x 1 1/4 Big Bucks!
David, you are correct.
I buy the Sopko hubs from McMaster. They run around $65 last time I bought one.
Sopko hubs also appear from time to time on eBay. I bought 6 of them last year in a lot for around $30.00 a unit. If you're not in a hurry do a search on eBay. If nothing you're interested in shows up save the search. When something does show up with your key words in it you'll get a notification.
I got 4 sopro hubs on eBay for $90
And $90 for a half inch wheel jeez that is expensive. I’m pretty sure I’ve seen them cheaper but that was some time ago.
$90 for four is a great deal!
Whats real nice is I get a endless slightly fresh supply of wheels that are ~180mm dia, 50mm hub 10mm wide of 38A120 5SG180 5SG80 and even a 39CA500. I just have to make a 3d printed spacer for the hub size.
We also use a resin wheel 3NQP90 (sound about right) from Norton.
I am impressed!
Best wheel yet.
It only took two .002” passes with the diamond to clean up the pencil marks.
Great surface, no balance required.
$179 for one of those wheels for my Bridgeport SG
What grit did you get Jeff?
That is what I was thinking. The "46" is just peeking through by the hub. The "J' is the hardness of the stone with A being the softest and Z being the hardest. V is for vitrified. The S at the end might be proprietary. Not sure.
This is the first time I have used the ceramic technology.
Every Norton wheel I have purchased, made in Mexico, has been out of round.
This one is top quality.
