Someone will likely correct me but I think that an engine lathe is larger than most hobby, vocational lathes. I had a South Bend 14 inch (referring to the size of material that can be turned) engine lathe. It was enormous. I now have an Atlas 10”, fully restored and it is what I would call “screw cutting” or a light duty/hobby lathe. Back gears are simply like having 1st and 2nd in your cars transmission. If you want to go super slow, or have lots of power, use them. Typically you would just use the other speeds; always starting in 3rd or 4th“ so to speak. I hope this hasn’t confused you further. Good luck. Great hobby. Avoid buying cheap if you can; you’ll either end up buying twice, or frustrated. Cheers.
