- Nov 14, 2011
- 27
Most work has been held either in the 3 jaw or a drill chuck mounted on an arbor. I will have to try with both chucks and see which is the problem, I was just thinking the same thing. If it is unbalanced, how many wheel weights can I glue to it?:whistle:
Pierre
Instead of adding wheel weights to the light side, I think that MSC sells do-it-yourself hole kits. You can just add holes to the heavy side.
