- Jun 19, 2024
- 11
My 36" Atlas started makes this weird ringing / rubbing noise about 8 months ago, and I just can't figure out what's causing it. POsting up a few video link here so you can point me in the direction / tell me how stupid I;m being (and I don;t case, the noise it driving me mad).
I'm pretty sure it something do do with the pulley assy on the spindle, as it has the right hollow "tone". It's defo not the motor, and it's much worse on the higher speed pulleys. Backgear makes it quieter, but prob just due to the lower spindle speeds. There a little lateral play in where the pulley assy locks to the shaft via that collar to the LHS, but not much. Also the main gear on the RHS is pretty tight to the pulley too, and obviously is locked in place when not on the backgear.
My other idea is the front spindle bearing (timken) has gone bad but it feels fine and smooth.
Many thanks in advance,
JB
hi speed, no backgear:
low speed, no backgear, noisy:
low speed, backgear, a little noise:
high speed, backgeared, not bad:
JB
