I run my el cheapo at 30psi using a cheap HF air regulator. Then use the needle valve on the unit to adjust the flow for both the air and the fluid. My compressor has an 80 gallon tank, I leave the power switch off most of the time. The mister can run for hours on that tank without needing to run the motor. I just tweak it to get the type and amount of spray I want. I generally aim for small drops, just enough to keep a slight sheen on the part while machining it. Most of the fluid evaporates off from the heat while cutting. When not actively cutting, I use a ball valve to turn the air off. Mostly so I don't have to listen to the hiss while setting up operations.
