Not at all. In fact, I have very rarely used "true" MAPP gas for sweating copper pipes. I used to own a house that had an electrolysis problem, and it would chew through copper pipes like mad. I got to be very good at sweating copper pipe. Absolutely no issues whatsoever, even when it was cold. Now, if you are trying to fix a leak with the water still in the line, that would be a no beuno.
A little trick for sweating copper when there is a little water left in them (that tiny drip, drip that will ruin your solder joint) is to get yourself some cheap white bread (no wheat or anything like that) and stuff enough up the pipe to stop the drip. Get it soldered together quickly before the water makes it past the bread. Once you turn the water back on, the bread disintegrates, and you are back in business.
