- Jun 6, 2021
- 25
I guess a little spoiler alert. The dies can be slightly under sized. I am making the dies out of A11 tool steel as it better maintains the original machined size after heat treat and tempering processes. After this I am going to apply a ZirN coating and this coating can be applied in a few layers to achieve the final size dimension. So I am not solely relying on the EDM for end result die size. Just getting it as close as I can.I don't know what your experience is in tool & die work so maybe you can pull this off. But, in order to operate at the clearances you suggest, you are going to need an incredibly tight and rigid setup.
Ultimately, I want sets of dies with this coating and when wear etc occurs I can electro-strip the coating off and re-apply the coating and never have to make or buy dies again.
ZirN coating has Rc80 and a coefficient of friction of .05 just a little less than Teflon.
The dies will have a .0002 chamfer as well to maximize cutting/tool life etc. I have thought and planned this out I just don't have the equipment to make what I need.
