Newbie Questions Re X2 Mini Mill
I'm using this for spindle speed... No batteries to buy and I can't misplace it.
http://www.ebay.com/itm/172179028474?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
I'm using the [URL='http://www.machtach.com/']MachTach kit for rpm and surface speed. I love it. [/URL]
[URL='http://www.machtach.com/'][URL='http://www.hobby-machinist.com/attachments/dsc_0348-small-jpg.129304/?temp_hash=6e076204794cbe1737a3cfd5e99d869d'][URL='http://www.machtach.com/'] Henry Arnold sells the kits and is a wonderful man to deal with.[/URL]
The kit is very easy to assemble. You must solder components and wires on the circuit boards. I taught high reliability soldering and board repair at the local vo-tech and for an Aircraft manufacturer repair shop so it may seem simple for me but anyone can learn to solder quickly. I use the optional wall wart to power the tachs.
Dsc_0348 small.jpg [/URL][/URL]
I used the magnetic pickup option and made a mag ring and housing to mount on the lower spindle bearing Dsc_0349 small.jpgcover.
I also added a set of flood lamps and touch switch.
I also have the MachTach on the mini lathe.
