[Newbie] Newbie Mill-Drill Input questions
The ones on the LMS comparisons are the X2 and SX2 models. Quite a bit smaller than the X3.
Since it doesn't sound like you will be doing big production milling, I would say that the biggest consideration is the work envelope. The stiffness can be overcome by smaller cutters and lighter cuts. A lot of people have the square column mills and do good work with them. In that price range you are looking at an X3 or similar unless you are patient and can watch for something used.
David is correct regarding the work envelope. I have a Hardinge TM, which I -love- .. But even having a 6x26 table I find that once in a while I have to be pretty create if I want to use a 5 inch diameter flycutter on a piece 7inches long.
But this machine fits my space well, so I do with what I have :)
Bernie
