- Jan 28, 2018
- 18
You are going to need a better step stool to stand on for taking pictures. Does that shop where the FIL works have any other Sharp mills of this model that you can look at? I found a picture of a motor name plate on the internet - it shows as 3 HP, "DESING CNS-C-112". As others have posted above, you may have a "C" face mount. However, there are other face mounting arrangements. Sometimes you can make up an adapter plate to use a motor that is more available (that lathe is going to be very handy to help get the mill going, and for many other tasks).
Good luck with making some $$ on the side.
Thanks. Here is a picture of another sharp mill that was in use the day I picked up mine. I took a picture of the motor that was on it.
