- May 31, 2018
- 36
Hello,
I recently picked up this 101.07301 for $200. I’ve cleaned it up a bit, gone thru the oiling process, and built a base for the lathe. This lathe has a custom built countershaft setup (I was unaware of this when I bought it but after research and further examination it is definitely not factory). I am unsure of the best way to mount the motor and countershaft assembly. I need the ability to loosen the belt for speed changes and the countershaft only has three pulleys while the headstock has four. I have a tendency to over complicate things before I get them right so I figured I would ask for ideas before I build something that’s going to be difficult to use. Thanks in advance!
