Newb quick change tool post/tooling suggestions
Yeah, I tried just kind of laying out the t-nut in different chuck/jaws/spaced configurations. I don't see how to do the Dutchman cut in this without collision. I'll see if I can hire someone here to mill mine down...you are very spot on WineGrower. After the mill it will be the CNC upgrade as well....
Just an FYI - you can make a nut for your QTCP only using the lathe. Here is one I made one my SB 11" before I bought my mill...
Stock held in 4-jaw and "facing"/cutting it to width:
Marked out the width of the slot:
Shimmed up with a 1-2-3 block and cutting for the slot:
Ready to cut to the proper "depth":
Hope that helps,
-Ron
Ron, that's awesome! It's that step where you have the 1-2-3 block shimming the t-nut out that's super hairy. I don't see how to pull that off without collision. Perhaps now that I see that may not be as crazy and dangerous as I thought it was, I'll give it a whirl.
Thank everyone for the advice and offers to help!
I do not want to hijack GON's thread but can someone explain to me why one wouldn't just re-drill and tap the existing t nut to fit the QCTP stud instead of milling a new one? I understand the normal QCTP stud to be 14mm x 1.5 which is larger than the original stud. I'm obviously missing something here and trying to learn. Thanks in advance.
Something that I have done when needing a T nut is to use a carriage bolt. The flats typically need a little cleanup with a file to fit the slot and grind flats on the round edge to fit also. Sometimes the head also needs to be flattened to fit. Not as elegant as a T nut but it gets the job done. Only takes a couple of minutes.
For sure let someone seasoned answer this, but there can't be any reason why the stock t-nut couldn't be used. Truth be told, it is a much more complete fit than the blank sent to me with QCTP, it's a bit short. Ultimately you are machining the blank to be as close to original as possible. It wouldn't be logical, but once I tap this stock one, the old is useless unless I make a new one....but yeah, why wouldn't anyone to backwards unless you buy cheap Chinese junk that doesn't have any consistancy..
Replacement is available from Grizzly for $4.
http://www.grizzly.com/parts/TOOL-REST-SLIDE-PLATE/P0602222
Man Ron! I tried mocking that setup with 1-2-3 blocks and it is a mess! Like 3mm hanging on to that t-nut for dear life! With the tool post and dead center in there, it's like 6 kids putting their hands into the candy bar to fight over the last piece of candy....DEAR LORD!
