David,How is the setup working. I have a set of igaging scales that I picked up cheap and I'm debating whether of not to go the TouchDRO setup for my lathe.
@ycroosh Does the Touch DRO allow the measurement to show diameter reduction instead of direct measurement?
On my mill I had some of the flickering/numerical jumping about issues that others have reported, likely related to the DRO being on the same power circuit as the 2hp motor. I have since built a VFD controller with a 3 phase motor that is supplied from a separate circuit and which has an EMI filter in the control box. While I have just finished that project recently and have only an hour or so of use since, this seemed to clear that up.How is the setup working. I have a set of igaging scales that I picked up cheap and I'm debating whether of not to go the TouchDRO setup for my lathe.
Thanks Yuriy!David,
In "lathe" mode it has a button to switch between radius and diameter reading.
Regards
Yuriy
You're welcomeThanks Yuriy!
Thanks Yuriy, I have yet to install the scales so the timing may work out in my favour.You're welcome
To answer the second part of your question (which I ignored) - current version of the app has pretty basic Lathe functionality. You get radius/dimeter reading, a way to store sub-datums (points), and a bugger display.
The new version (which will be ready for "private testing" [hopefully] in a week or two has much more lathe-centric functionality, particularly a more full-featured graphical view, "boundaries" and easy tool swapping. I'm planning to add more "creature comfort" to the lathe mode type of stuff in the coming months.
Regards
Yuriy
