I pulled things apart a bit more for inspection and just for the sake of learning how this works and how it is put together. I did figure out that the oil reservoir up at the top is used to feed "fresh" oil to the spindle screw and also that same oil runs down the screw threads and is collected by the heavy spindle casting where there are two channels used to send oil to the ways. It is actually pretty clever and elegant.
Oil is pumped up here-
and then it runs down the threads of the screw until it gets to these channels that feed the ways-
Another thing I am quite pleased with is the overall condition of the ways. The scraping looks very fresh and shows little signs of wear on both the spindle column and the saddle.
The nice part is that all this oil just drops right back down into the sump where it can be recirculated (pump is at the bottom of the lower sump) shown above...
I am sure the way this works is not unusual or even slightly interesting to most people but it is all new to me...
I did confirm that since it has ball ways for the table, there is no need to have continuous oil flow onto the ways making them less susceptible to grinding dust contamination. I do have a manual for the Super 612 but it does not cover ball ways maintenance procedures so I would like to hear from others who have experience with this configuration.
That is all good news. The bad news is that all outer insulation for the wiring is hard and cracking. I need to completely rewire this machine in order to make sure it is good to go for years to come. I will need to find some of this heavy gauge stuff to make it appear more or less original so that will probably be my next step...
BTW @Cadillac The orange thing in the previous post is a Lotus Elise
