I am not even sure which clone I have or if it is really a RF or how to tell them apart, but it is mine.
It does have what appears to be an identical quill and I found this section of the forum when I was searching for the bearings that I knew that would fit. The model number just says 2666-0515, the sticker on the front says Rutland Tool & Supply, CA
So far I have it completely apart and am replacing all the bearings, belts, and lubing, cleaning, maybe painting. I plan to add some jog buttons for fwd and rev. I already have a 3 axiz DRO as you can see in the pics.
1. What should I call this thing, aka is there a clone number that matches this?
2. Any other must have mods?
3. For those that have used angular contact bearings on their spindle, how did you preload them?
It seems that the cheaper ones are 40 degree ball angle units, so it seems that you could just tighten the nuts pretty tight and not worry about it. I do have a infrared temp gun so I figure that will tell me if I went too crazy. My top speed is only around 1400 or so? I have not measured it yet. It is a 1986 Taiwan model with a Clausing style variable speed counter-shaft drive.
