New To Me Grizzly G0709 14 X 40 Lathe
I have a G0709 and really like it too. Does anyone know of anyone converting one to CNC?
Here is what I bought:
Carriage Lock:
6848K52 Metric Die Cast Zinc Adjustable Handle, M8 X 1.25 Thread X 60MM Stud
Cross slide and compound:
(Don't remember which length was required, I think the 30mm one for the cross slide and the 15mm for the compound, but they may have both required longer lengths, regardless I had to grind a bit off the end, shape the end, and touch up the threads):
6848K38 Metric Die Cast Zinc Adjustable Handle, M6 X 1 Thread X 30MM Stud
6848K35 Metric Die Cast Zinc Adjustable Handle, M6 X 1 Thread X 15MM Stud
Just a note: you need to hold onto the carriage lock assembly from beneath when you remove the cap screw from the top and hold it in position while you thread in the handle so you don't lose the pieces.
Handles look like this:
That's a nice setup! I will definitely be doing the same!
Very nice project you and Steven have going there, Bruce. Now, get that crank handle out of the way and mount a Chevy starter motor to the side with a bevel-gear setup. We'll be wanting video, of course... :encourage:
The G0709 is a really nice machine. I got tired of doing deep knee bends to change speeds on my 12 x 24 Clausing and after a lot of deliberation settled on the G0709. The Clausing still feels smoother to me, maybe years of turning chrome plated hourglass crank handles instead of satin finished loose tubes on shoulder bolts (Grizzly). I just ordered a 5-C lever style collet closer for it too. Really like the 5-C chuck on my Clausing but went with the lever style on the Grizzly. Haven't made anything yet that needed the 14 x 40 over my 12 x 24 Clausing. Did single point thread an M8 x 1.25 303 stainless screw for a new carriage lock (don't have metric change gears for the Clausing). This lathe is a dream machine for going between English and metric threads, one knob on the gear box changes between E/M. No changing gears on the quadrant (depending on coarseness of thread). I also put the taper attachment on the lathe which my son uses to turn (of all things) chop sticks. Granted, they are out of zebrawood, cocobolo, purple heart and other exotics, but chop sticks?!?!?
Ironically, my 19-year old son Steven (him in the photo on the Clausing) and I just finished up the majority of work for the gun project pictured. Nothing was turned on my "Gunsmith" lathe, just the Clausing. We're to the fine tuning stage at present. Next will be a tripod mount and an oak box to house everything. Caliber is .22 short/ .22 long or .22 lr (pictured). Oh do I long for the $10 for a 500 round brick days . . . should crack off about $50 worth of ammo per minute at today's prices.
Bruce
View attachment 114981 View attachment 114982 View attachment 114983 View attachment 114984 View attachment 114985 View attachment 114986
Tell your son , some exotics can be deadly , even the sanding dust from them. You don't want to get sick .
I love the gat, hope to build one someday in 22 mag of course. Or even 45 colt yupp
I got the OK from the boss to upgrade lathes. I settled on a Grizzly G0709 14 x 40 after considering a number of options. Won't bore everyone with all of the details, but I liked Grizzly's service rep, D1-5 spindle, brake, coolant and especially the universal quick change gear box. I ordered it on September 29, got the call from UPS Freight on October 2 to schedule a delivery.
Fortunately for me my brother-in-law has a truck dock and fork truck. Grizzly told me that because of the weight of the machine (1550 lbs.), power tailgate was not an options. I'm sure I've read other threads where mills have been delivered via Tommy-lift, but it wasn't an option for me.
Getting the crate off is a bit of a chore, lots of tabs to bend to lift off the top. Then lots of nails to pull to break down the crate. Unloading from my trailer was pretty painless because of my HF gantry crane. Wonderful piece of equipment by the way. If you have space for one, buy it! I used 830 lbs. rated ratchet straps on each corner which work well for balancing the load. It's hard to see in the photos, but I ran a loop of 1/4" cable also after the load was balanced for belt and suspenders.
Others have had shipping problems with their similar lathes, I did also. My tail stock under-bed clamp worked its way loose and fell in the chip pan. Fortunately the tail stock stayed on the top side of the bed though it did contact the carriage and chipped a little paint. The top knurled nut holding the back side head stock cover loosened up also. No damage here, nut was trapped under the flip-up sheet metal cover. The M5 set screw that retains the flip up cover to access the spindle spider was missing also. The High/Low range shift lever worked its way loose and was also in the bottom of the crate.
I broke the lathe in per Grizzly's instructions and changed the headstock and gear box fluid. I bought ISO 32 and ISO 68 oil from Tractor Supply for around $25 for 2 gallons. The drained fluid looked new; no chips, dirt or anything.
My other two lathes are a Delta/Rockwell 10 x 36 and a Clausing 5418 12 x 24. I owned an Atlas 12" some years ago which emcompasses my experience on turning tools. I'll add to this thread as I gain more experience on the Grizzly. Here are my first impressions (some are personal preferences based on my other lathe's set ups):
I really like the gear head speed shifting as compared to my Clausing's belt drive. Mine shifts very smoothly, need just a little turn of the chuck to get the gears to drop in. High / Low range is no problem. I have some issues shifting between the 4 speeds, probably operator error/experience more than anything. More than once I thought the lathe was in gear, hit the Jog button and spun the motor but not the spindle. I'm am getting better with experience.
The power switches on the headstock are inadequately mounted in my opinion. The 0.040" (give or take) thick aluminum screen printed panel cover is about 15" x 10" and is secured in the corners and on the sides. The switches mount to the thin aluminum and flex in/out too much for my liking. I pulled the panel and reinforced the switch area with a pieces of aluminum 1/8" thick x ~10" x 2". Much stiffer now.
I also don't like the micrometer dials on the cross feed and compound. They are large enough to easily read, but I'm used to loosening a lock screw, freely turning the wheel to position and locking it back down. This lathe uses a friction clutch of sorts to position the dials. According to the parts drawings there are two springs and balls under the dials to add some friction. You need to hold the handles rock steady as you turn the dials to zero. I'm concerned that the crank will move a bit as the dial is rotated regardless of how carefully I hold the crank. I'm likely adding a taper attachment to this lathe which gives me a new cross feed arrangement, will likely drill and tap a hole in dial to add a locking screw and lose the springs/balls. Maybe I'll get used to it over time.
I did some single point threading for an M8 x 1.25 bolt to replace the carriage locking bolt. It's a cap screw as designed. I made a 303 stainless screw/clamp arm for locking the carriage. No issue with the threads. Love being able to switch between most metric and english threads without fiddling with head stock end gears.
I had to adjust the tail stock to center up with the spindle. Others noted having problems with this but it didn't take me long at all. Same adjustment as my Clausing and Rockwell lathes; loosen one screw, tighten the other to offset the center. Mine is better than 0.0005" over 12" (for now).
I haven't checked the accuracy of the compound protractor yet, heard from others it's off. I did my M8 x 1.25 with the compound set to 60 deg. Thread came out fine. The protractor only covers 120 degrees of rotation, both my Clausing and Rockwell are graduated through a couple of clocking marks to a full 360.
One thing I don't like about the compound is you can't swing it a full 360. The crank on the compound will hit the light and coolant nozzle when swung 120 deg. from straight on. Chamfering will be done with the compound swung towards the chuck instead around to the back side of the bed.
QCTP lock lever is off by 90 degrees from I'm used to. I've seen a couple of youtube videos of other guys with the same thing so it's probably on most/all of them. The piston style post has the two typical dovetails that I'll call turning/facing and boring. The lock lever for facing is locked either at about 7 o'clock or 1 o'clock. 1 o'clock is over your work if you're turning something long. I'm used to the lever ending up at around 5 o'clock when locked. So why not use the lever at the 7 o'clock locking position? To unlock it you turn it to 8 o'clock which puts the lever just over the tool holder. Can't lift the tool holder off because it's under the lock lever. I fixed it by pulling the two plates that move in/out on the tool post and ground about 0.025" off the front/back. My lock lever now locks in place at 5 o'clock for both turning/facing and boring.
Really like having a back splash for keeping swarf off the floor. I'm going to lose the sheet metal spreader between the head stock and tail stock cabinets and replace it with a shelf/drawer unit. Not that I want to do a lot of deep knee bends to grab stuff from under the bed, it's just my personal preference. Seems like a good place to put the tool box, steady/follow rests and faceplate. I'm going to repurpose the spreader by turning it into a back splash on my Clausing lathe.
Longitudinal cranking is about 1/2 the travel per turn as my Clausing; 9/16" on the Grizzly, just over an inch on the Clausing. On the plus side the Grizzly longitudinal crank is graduated; easy to tell how much you're taking off when facing.
Overall I'm very happy at this point. I parted a 1 1/2" round of 303 stainless with a HSS cut off blade with no incidents. Not a hint of chatter.
I'll post updates as I get more experienced on the lathe.
Bruce
View attachment 112483 View attachment 112484 View attachment 112485 View attachment 112486 View attachment 112487
BG Hansen, if you still have this lathe; would you please remove the left cover near the floor and shoot a picture of the setup for the brake connections. I recently moved my lathe and had to remove the emergency brake. Need a shot of the 3/4" rod that goes through the cabinet and how it engages the microswitch, etc.
Tks,
John
Tks,
John
Here you go. One with the rod contacting the leaf spring is in the un-tripped position. Other is the tripped position with my hand doing the honors.
Bruce
Don't suppose I could bother one of you guys who own a G0709 to measure the width (long axis, left to right as you standing in front of the lathe) of your slide out chip pan?
I just created a post with a question about this, describing my plan to retrofit a G0709 slide out chip pan into my Birmingham lathe, before I saw this post. I'm still in the info gathering stage.
Grizzly is a half hour drive from my house. If the idea looks do-able, I'll run by next week and pick up the pan.
41 ⅜" across
Thanks for replying.
I've already got the chip drawer installed.
The stand pedestals, pans, drawer etc are all at the local powder coated getting a coat of old Southbend gray.
While I had it apart, I put in a set of Timken spindle bearings and changed the oil. It was pretty foamy:
3d printed some way wipes for the saddle
Replaced the bearings and fan in the motor, and Cerakoted the knobs and headstock cover.
