First off, thank you everyone for replying to this post.
Did anyone happen to look at the pictures I posted on my last post? I was wondering if I have everything in the correct place? Not so much the carriage assembly, but the gears and pulleys. I'm pretty sure I have everything where it is supposed to be, and I don't have any left over parts laying around. LoL
Okay let's start with Jon's reply about the QCTP. Once I get the Lathe back together again. The only thing I have to try out the Lathe and it's cutting ability is the rocker style tool post. So I'll be messing around with that until I can get something better. Plus I already have just about every cutting attachment that goes with the rocker tool post. I have heard that the AXA wedge type QCTP work really well with these old Atlas Craftsman Lathe's. And I have looked at a few places that sell them. Shars seems to have a good price on their AXA, so I might go with what they have.
And on a parting note Jon, if or when you have time. Please take some pictures of your Atlas horizontal mill and Atlas Lathe. I would love to see what your machines look like compared to mine.
Next is good old Robert, and if you don't know Robert. He is a plethora of information on these mills and lathes!!! This guy has helped me out quite a few times with my mill and lathe. And always goes above and beyond to help me with my questions.
Okay enough about Robert, let's get back to the Q&A. LoL About the motor issue with 1/2hp versus 1/3hp since I already have the 1/2hp motor wired up with a forward and reverse switch. I'm going to put that one on the Lathe, that is after I take it off the mill. The old 1/3hp motor will end up on the mill. Plus the 1/2hp motor is a capacitor start motor and the 1/3hp is really old and will probably be a good match for the mill. And there is no reason to have a forward and reverse switch on the mill that I know of?
Now let's get into the miter gear issue. Though it looked as if the miter gear might have sheared off at one point. I've looked at it quite a few times and to me. I just don't see any obvious area inside the miter gear were the internal key might have sheared off? And another thing that is kind of strange, is that the Scroll does not have the flat area for the Plunger to go into for the cross feed?
Just seems to me that "if" the Scroll did have a flat area. Then it would make sense that the miter gear might have sheared off at one point because of something in the carriage assembly being locked up. Or like Robert is saying, that maybe someone crashed the carriage assembly into the chuck.
Okay, now that I have talked about the above mentioned. Let's get into Robert's last post about the interlock between the power cross feed and the traverse feed. So I guess what you are saying is, that when you pull the knob for the power cross feed. That the cross feed will go in the opposite direction coming back instead of going forward when you are facing off a part. Did I get that right? I'm not sure of the 10D-38 you speak of, only the L6-38 which is the Scroll (which in the PDF looks to be round). So if you could, please entertain us with your knowledge of the L6-38 and where I can find it.
Thanks again guys for all your help. It is truly appreciated!!!
