Thank you! I'd like to see how you set your tumbler up! I would imagine that is true about the larger lathe. Coming from a little Chinese 7x10 Mini Lathe, I feel like I'm driving a Ferrari now thoughYou have done an amazing job on this lathe. I will try dig up what I made as a reverse tumbler for this lathe. I haven't used this lathe in about eight years. When you have its big brother you dont want to play with it anymore
Thank you!Sure came out purty! Nothing like a complete tear down to familiarize yourself with your machine. You did a fine job on this one - congrats!
For the life of me, I can't figure out what would keep it from turning in there when you tighten down the lever and mine did. I did notice that there are different part numbers for the top and bottom cotter halves, maybe one has a hex shaped recess to trap the bolt head???
I'm betting this one had a hex recess in the bottom cotter. I didn't have that part, but that is the only way I can see that working out right. Thanks for the info!For what it's worth, Atlas used a similar arrangement on the tailstock ram of the six inch lathe and perhaps other models as well. They solved the spinning bolt problem with a square-head fastener and matching socket in the lower half of the cotter. I know this Emco is not an Atlas, but the feature in question is very similar.
-frank
I may do that at some point!A Dremel tool is your friend if you want to cut one in. Very easy to do, and it need not be a flawless fit to do the job.
