- Sep 26, 2018
- 192
sorry guys. its the original toggle switch...think i'm going to do flexible conduit it into a t-conduit box. i have it wired up and working roughly now...i just wanted to see what the original hardware looked like
wow.Atlas didn't sell lathes with motors installed, or for that matter even included, unless you bought a motor from them at the same time that you ordered the lathe. So technically there is no original wiring. As best I can determine, when you un-crated your new 10F, what you found was a 2-wire pigtail connected to the headstock mounted switch at one end and connected to nothing at the other. After installing the motor mechanically, you opened up the junction box on the motor, added a (in those days most likely 2-wire) line cord, spliced the black line cord lead to the black switch lead, and connected the white switch lead and the white line cord lead to their appropriate terminals. Then you replaced the cover over the junction box. And if you were at least half smart, you test ran the motor before installing the motor belt. Today, you would also connect the two green wires to a grounded screw or screws. And if you are at least half smart, you wrap a short length of black tape or black shrink tubing around the white switch lead to signify that it might be hot.
The flexible conduit is a good idea. It will keep the switch lead from getting oil soaked.
first i have to put levelling feet on my mobile tool cart. i have a starrett machinists level...time to learn how to do that now thanx againIt certainly looks nice. Have you leveled the bed? Actually, it doesn't have to be level, but both ways must be in the same plane. And the cheapest and easiest way to achieve that without great expense is with a level
