Yes sir! That is what I'd use, eventually.You probably already know but you can use a link V belt in place of the belt to drive it so you don't have to remove the spindle to put a new V belt on. Just be sure to get the right size 5/8?
It appears you have a broken casting on the back. You can probably part it out for more than you paid for it. The QC gearboxes demand high dollars. I don't recall seeing one with the internal back gear setup, but then again mine is the only Atlas I've come into contact with. Mike
Thank you! This is my thought as well.So all you're actually missing is a tailstock, a motor, and a countershaft? If the spindle turns free, without wobbling, I don't see the harm in assembling it, and trying to run it.
Congratulations on your first lathe, and the beginning of a stop/start, stick/slip, head scratching fun adventure!
I've got my eyes open for a good used treadmill. I'll find someone tired of hanging laundry on it and help them recycle it sooner or later.Since you need a motor it is an opportunity to use a treadmill motor to get infinite speed control and torque.
A good size treadmill motor has plenty of torque as they can keep running while a 300 lb person is jumping up and down on the belt!
Full disclosure: I did what you're about to do. As did so many others. The advice to "part it out" is well meaning, and wrought from experience. It's just that I can tell you want to play with this one. I know what that's like. There's plenty to learn by going this route, and you seem to have the temperament to make it worthwhile. And anyways it's an Atlas. If it doesn't work out, you've got more than enough there to get your money back in parts. And you'll get a lot of free experience in the meantime. Have fun! I love my formerly basket case Atlas. It's just right for me.Thank you! This is my thought as well.
Here is one in Garland from the Dallas Craigslist. There are a couple more there too. If I were you I would search cities close and try to get one with the controllerI've got my eyes open for a good used treadmill. I'll find someone tired of hanging laundry on it and help them recycle it sooner or later.
