Phase Perfect is not a static converter, it generates the third leg the same as a VFD does, the difference is that it is a single leg which is sized much larger than a conventional VFD (to handle the load) and it is extensively filtered to produce a sinusoidal output. They have been around for many years, and for the most part have been very reliable and durable. They are very simple to install, they do not need to be oversized. If you were to use it for both machines you would need the 5Hp units assuming you are running one machine at a time, if both then the 7.5 Hp model should be sufficient as you will not be loading both at maximum at the same time. There have been other threads discussion of Phase Perfect and RPC's. Cost wise, when you get into the size VFD needed for a 3Hp and 5Hp motor with separate installs, you are in the same price range as the Phase Perfect or a store bought RPC.
I just asked this in GJ, but I’m thinking some people here might have good insights specifically related to the hobby. So I am going to buy a small 5hp phase converter to run my 1.5hp Bridgeport. I have done some research into American Rotary Phase Converters and they use Baldor motors which I...
www.hobby-machinist.com
www.phasetechnologies.com
