I've been working on the lift mechanism, first attempt failed, the linear actuator I got was to small, it could lift the motor but couldn't hold it. I ordered a new one that is a lot stronger and unfortunately a lot bigger also. Couldn't find anything just a little bit bigger...
This is the first one mocked up.
This is the one that can hold it up.
I made a couple shoulder bolts to mount it.
this second one has a step for the adjustment slot on the lift arm.
The whole mechanism together.
I still need to make a list and get all the proper stainless hardware.
and videos of it working.
Now for some more glass work, I need to add several layers to the area the linear actuator bracket will mount, I'm going to use flat head screws from inside the cast so I need it thick enough to countersink the heads so they don't scratch the boat, then it will be screwed on with a wet layer of glass for a perfect fit...
