- Jul 6, 2016
- 102
Thank you very much for the fast response.If you don't mind how it looks you could just turn it down intersecting the extra holes. Most back plates match the diameter of the chuck but this is not mandatory. The back plate can be a little smaller or even theoretically larger. The registration boss is the critical diameter.
Robert
I assumed that was the case as I tend to overthink everything. However being so new to Machining I figured I better get a qualified response from someone that knows more than me. The funny thing is I have for other Chucks and every single one of them the backplate is noticeably smaller then the Chuck itself. That should have been my first clue LOL.
The Chuck should be here anytime now I'm getting very excited LOL. I just got done meticulously measuring the intrinsic runout on my spindle which was barely readable perhaps one ten thousandths if that. I don't know if that's really high or low before a lathe built in 1946 I'll take it.
This will be my second backplate that I've ever made but again the last one was unsuccessful because the scroll itself ended up being the problem. So I guess I can't really say that I failed at making the backplate it just did not solve the problem LOL
Thank you for allowing me to briefly hijack this thread
Jeff
Can I junk phone in and ask a related question?
I have a 3 jaw Chuck coming ups in the morning.
I have a 7.25" used backplate that was a failed attempt to fix very old chucks runout issue.
I would like to use this for the little 6 inch chuck that is coming as it is still new, unmarked and.. .80 thick over all.
My problem is that the old mounting holes will indicate up being right at the edge of the new chuck. Just barely!
Csn I turn this backplate down 100 thou smaller then the new chuck? I looked at all of my chucks and it seems like every one of them is a little larger than thier mated back plate...
Is this the way it is done typically?
I really don't want to wait to get another new blank BP and trash this one simple because there is a 16th inch over lap with the old mounting holes.
Anyone?
Sent from my SM-T800 using Tapatalk
