Hi Mark:
I know that it is not my thread but I have the 833T also. It is a very nice machine with the fit and finish being very, very good. The Taiwan built machines are definitely worth the money. I have not used it a lot so don't have a much to say about it other than you would not be dissapointed to have one in your shop.
Looks like a great machine. Has it met your expectations now that you have had it for some time? Was there a three phase option by chance?
IT IS DEFINITELY A CUT ABOVE MOST ASIAN TABLE MILLS .
I LOVE THE SIZE AND RANGES OF TRAVEL , YOU CAN DO SOME SERIOUS WORK ON THIS MACHINE .
I DON'T LIKE THE NOISE OF THE GEAR TRAIN . HAVING RUN BELT DRIVEN MILLS FOR SO MANY YEARS
IT IS QUITE ANNOYING ESPECIALLY IN HIGHER SPEEDS .
IT DOES NOT HAVE THE RIDGIDITY OF A BRIDGEPORT FOR HEAVY CUTS AND YOU CAN TELL THE DIFFERENCE
IN THE FINISH OF SIDE CUTS .
MY MACHINE IS 220 SINGLE PHASE . I NEVER ASKED ABOUT A 3 PHASE OPTION .
I AM SURE THAT MATT AT PRECISION MATTHEWS CAN ANSWER THAT QUESTION . http://www.precisionmatthews.com/shop/pm-833t/
Thanks guys! Getting close to buying a mill. I wonder how it would compare to the real Rong Fu rf 45. I know it has less travel but it seems to have a good reputation with it s good castings and how the column has five bolts vs. Most with four. Decent bearings and such. About a grand cheaper than the 833t. Might even buy the rf 31 if I end up jacking in my job. Yes a round column but many solutions out there and i do really prefer a belt drive and the better rpm range. Yes the pm 835 s looks like a contender but with only the head from Taiwan i am a little weary about it. Matt does put the effort in as I would think it would be of decent quality with the pm badge.
Rimspoke one stat I have never seen anywhere is the swing for the 833t. Very Decent travels and better than a bridgeport spindle to table distance. I keep coming back to this machine for the quality.
