- Jan 20, 2016
- 602
I have heard a lot of people saying the same, but I wouldn't really bother. It doesn't end up being too practical to turn handles through the motors. You need to turn the motors off so that they aren't holding their position anymore, but that means the controller loses its position and you will need to re-touch off or rehome before using CNC again. Even then, the steppers have detent positions so while you turn the handles, you feel clicks as it moves. Simply jogging manually does the same thing, just through the controller.I was thinking of going with 2 shaft steppers so as not to lose manual mode but with a pendent fitted I think I can do the same thing as manual but using each motor to wind the handles.
That change must have been made before I got mine as mine is roughly 70mm (I measure in imperial, I am actually getting about 71.8mm spacing). But thanks for looking out, that would have been rough if I made a bunch of parts that no one would ever need.For th OP shooter123456, the newer pm25mv have been modified, the X and Y endplates now have 70mm centres on the fixing bolts to table so dont rush out too many kits at the old measurment of 120mm between centres as you might get stuck with them for a while.
Shoot me a private message with your email address and I can send you some models.If you would sell a copy of your drawings, especially the fastening nuts that fasten ballnut to table/sled, I would be interested as I'm not looking forward to modeling especially Z axis, disasemble check fit, reasemble and modify a couple of times to get it right, then repeating same on other axis. Let me know.
Those motors might be a bit overkill, but nothing wrong with going bigger than needed. I had great success with 400 oz in steppers for X and Y and their limitations were limited to speed which stronger motors wouldn't have helped. Also, make sure you double check the dimensions for whichever motors you use. I just had an issue in the past few weeks where I had to make some new parts for someone because they were using Nema 24 motors and the mounts didn't have the correct hole spacing. Even though it is supposed to be standard, some manufacturers take liberties with the standards.I've been thinking of using 5.5nm(778 oz/in) nema 24 al round or even next size down for X and Y, the nema 24's fit nema 23 mounting plates that I have so thats not a problem
