I am almost done with the new hardware for the X and Y axes. The goal was to protect the motors and coupler area better so they aren't always covered in chips. This will also be more important when I add flood coolant. The clearpath motors do not have water proof connections, so they can't be getting wet. The new hardware protects everything on all sides except the bottom. The new x axis will also have built in connections to supply power and air to the 4th axis (or pneumatic vise if I ever make something like that).
I also have a hankering for a new spindle. I think the current one could be much more rigid, smooth, and quiet. I think something that causes less vibration at high speeds could significantly improve surface finishes. I have been working on a design that would only require a little bit of modification to the current head to secure it. The new spindle would have 3 bearings (2x 7007 for the bottom and 1x 6906 bearing for the top. I am planning for around 10,000 RPM again, though hopefully much smoother running and no issues with pullout if I want to make heavier roughing cuts.
The new spindle is a little bit narrow once it gets into the head. That is to match the current spindle OD and avoid needing to make a new head or try to bore out the current one.
The new one will use 2 bearings on the lower end instead of just one, and they will be preloaded against each other. The bottom of the spindle is also much closer to the bottom of the bearings compared to the current spindle. Even with the flange and mountain adapter, the spindle sticks out slightly less.
Here is the plan with the new X and Y hardware, as well as the new spindle in the head.
I would be happy to hear opinions and ideas, especially if you see something that would keep this from working well.
