Re: started refurbish
Ben busy cleaning seventy year old grease chips scum off of heavy 10 "still trying to come up with a name for her".
Base , bed, pan, legs, doors, under-drive cleaned / painted. Used about all methods mentioned here for cleaning / paint striping
oileater in parts washer did a good job degreasing and some paint removal ,electrolysis, chemical, needle scalier, all worked good for different things.
Paint- Benjamin Moore dtm supper spec in pic. Took a top from a can of dark gray rustoleum i have been using on the small stuff to B-M store for a scan color match. I think there scanner is color blind , the color i got is gray with a purple tint to it and I had to drive 80 mi to the next county to get it {CAL} i got two gal's so i wouldn't run out. Didn't know it had purple tint till it was two coats dry after i moved it next to old atlas / craftsman that i painted with the rustoleum gray.
Sure enough just as i finished the final coat outside the guy across the street decided to plow and disk his field with the wind blowing my way. Got the parts in the shop as quick as i could but i don't think that dust made the purple tint. Any how it looks good it kinda grows on you. 3/4 hp 110v G.E motor going to shop to get checked out, ran fine sounded good just making sure.
Went by the felt book to dissemble the lower drive and the puller damaged a bearing shield so i found a place that has nos ones so i ordered both, the old ones were a little noisy anyhow. Things getting pricey and i'm just getting started .
I wanted to get the big stuff painted before the cold got here , I'll do the sub assemblies in the shop this winter hopefully with a little help from ya'll Thanks in advance.
Question- motor two step v belt pulley to the under drive two step flat belt pulley is it rite? running v belt.
O well this thing won't let me upload pics now for some reason ' i'll keep trying
Thanks
Derrick
Trying 640x480 123 kb pics do they need to be 800x600 332 kb
error said excedes quota by 6.99 mb
top of download screen says 7.16 mb of 293. kb used . Sorry Me and these things don't get along reel good sometimes win 8.1:angry: i'll try resizing to 800x600
