So I needed to move the machines into my part of the shop as I have a friend using my shop for car and boat storage for another 6 months.
I had been looking at CL for an engine hoist but never got my act together to go buy one and when I finally needed one today there was almost nothing available so I went and bought a new one.
Not knowing much about them I bought the Red one.
The workmanship on these hoists are OK but not great, I needed to thread chase most of the tapped holes but the rest went together pretty well.
Here is the first test for the new hoist, once I got the mill up off the floor the machine would not move, I was thinking maybe I should have got the Yellow one at this point as it had nylon wheels.
They are setup to push but not pull, so I used a wooden 2X4 to get it started, once I got the wheels all in the right direction I was able to manhandle it into the small room off the side of the main shop.
Now I went to work on moving the lathe which was still on the pallet and I didn't fancy chopping the pallet up as I didn't have a suitable power tool to cut it in place.
I removed the parts of the pallet that I could and slid the hoist in from the headstock end.
With the arm set to 1 Ton, I got enough reach to lift the headstock end, and it allowed me to move it toward the hoist by lifting the tailstock end by hand.
Here's how I rigged it up, I removed the chuck and used a tow strap that was 20ft long so I doubled it up and wound it around till both ends were even.
I did this until I needed to add bits of wood in the middle to hold the rear pedestal from falling through the pallet as there was still about 100lbs or so weight on that end.
Once it was free on the headstock end I had my son pull the pallet out while I straddled the pallet, held the end up and he pulled the pallet out, I was then able to lower the machine down.
Now I was able to lift from the middle with the strap wrapped around the bed and I moved the tail stock and apron outward until it was balanced.
With the lathe being much lighter it was easier to move it into the other room beside the Mill and now I can start cleaning and getting ready to start the wiring, DRO install and setup of the machines.
Thanks for checking this out, always nice to hear that some of you are enjoying these posts.
David
